08-08-04, 12:43 PM
IbgreY
Turn signal lights
OH
08-08-04, 04:22 PM
Usually a fast flash indicates that a bulb is burned out. Have your son put on the left turn - get out of the car and see what's flashing - front and rear. Then have him do the same with the right turn. If there is no flash on the right from a spot that did flash on the left side, he has isolated the problem.
08-09-04, 01:32 PM
Tuffdrvr
Short
Most likely you have a short in your steering column or dash area causing the lights to pulse faster on one side then the other. Power runs through your Turn Signal Flasher on your fuse box and it could have a short to ground. The only real way to pin point it is to take a multimeter and go hunting. The needle for the battery charge gauge probably bounces irratically when the lights are flashing right?
08-09-04, 02:45 PM
Posted By: Tuffdrvr Most likely you have a short in your steering column or dash area causing the lights to pulse faster on one side then the other. Power runs through your Turn Signal Flasher on your fuse box and it could have a short to ground. The only real way to pin point it is to take a multimeter and go hunting. The needle for the battery charge gauge probably bounces irratically when the lights are flashing right?I'm a little curious - how many steering columns/dashboards have you dismantled to "pinpoint" a bad t/s bulb? To the resident crew - is it just me, or does this stuff sound vaugely familiar?
To IbgreY - goldstar is correct, look for a bad bulb on the right side, although it may not necessarily be burned out.
