My Corolla is dead in another State S.O.S.
Joel Pags's Avatar
08-10-04, 08:44 AM   #1
Joel Pags
I was visiting my girl in Boston, i live in Nh, and my car died while i was on my way home. im in a desperate situation with it getting towed, i dont have the money! It just simply shut off at a stopsign, and wouldnt turnover, battery isnt dead, we went back and charged it, still wont work. S.O.S.
disability guy's Avatar
08-10-04, 09:05 AM   #2
disability guy
Can't say w/o more info
Hello:
Hard to say, could be electronic or fuel-related. Check fuses, battery ground, etc. If you're not able to discern these items someone who is knowledgeable will need to before it will crank. May involve a tow to a garage for a diagnosis.
Had a 92 with same symptom. Got lucky and found a dead 100 amp (yep, 100 amp) fuse on battery cable. $10 replacement from dealer since size is uncommon.
Good luck!
michael van's Avatar
TX
08-10-04, 09:09 AM   #3
maybe a year Toyota
Maybe a year Toyota might help also have you done anything to it?A little more info.
I am sure Toyotaman might be able to help.Also I asume you have plenty of fuel and your fuel guage is working.
Desi501's Avatar
08-10-04, 02:52 PM   #4
Posted By: Joel Pags It just simply shut off at a stopsign, and wouldnt turnover, battery isnt dead, we went back and charged it, still wont work. S.O.S.
That doesn't necessarily mean your battery is good. It's going to take a little more testing and information to get to the bottom of it.
Joel Pags's Avatar
08-10-04, 08:40 PM   #5
Joel Pags
hmmmm
well, i heard many things from many people, but most iv heard was about fuel, maybe bad gas, or a fuelpump failure...bad jets ect.ect.
o i forgot to mention, when it happened the first time(shutting off) the engine rumbled really low and shut off. then i started it again, and it rumbled lower and shut off again. maybe that helps.
slickshift's Avatar
08-10-04, 09:40 PM   #6
Again
What year and what engine?
Not to be pissy, but the Corolla's had a lot of different combo's
A year would help
An engine # (4A-F, 4A-FE), would be better
Not trying to be a smart ***, it really does make a diff
carguyinva's Avatar
VA
08-11-04, 05:46 AM   #7
you say...
...that it shut off and now won't turn over. what exactly does it do...or not do??
1. cranks (engine spins when the key is turned to the start position) but won't start
2. won't crank (doesn't turn over at all)
we need to know exactly what it's not doing here to be of real help...otherwise you just get a million suggestions and confusion with it.
tell us this first and let's go from there...
Joel Pags's Avatar
08-11-04, 07:46 AM   #8
Joel Pags
ok lets start again
1993 toyota corolla 4cyl not sure of engine type.
engine does crank but does not turn on.
slight odor of gas when peddal is pushed down,
i believe it is fuel injected.
carguyinva's Avatar
VA
08-11-04, 07:54 AM   #9
how many miles...
...and when did it have a timing belt last??
the low rumble is kind of strange....makes me wonder if the timing belt gave up.
slickshift's Avatar
08-11-04, 09:40 AM   #10
It really sounds like the timing belt broke
Joel Pags's Avatar
08-11-04, 12:28 PM   #11
Joel Pags
o god
how much does a timing belt cost?! i hope thats not the problem.
ripcurl's Avatar
08-11-04, 01:13 PM   #12
It's gonna cost at least 400 to do a timing job, I would estimate, but if your belt went, then your engine is toast. I believe those are interference engines in the corollas, so when the belt goes, the valves and pistons slam into each other. It would cause quite a shudder in the driveline. You need to give everyone more info thought, year, mileage, etc. Is it a regular corolla or a gts? The more info, the better.. What exactly can you remember happening when it quit on you? Did you smell or hear anything unordinary?
slickshift's Avatar
08-11-04, 01:22 PM   #13
Yes, some Corollas are interference engines but it happened stopped at a stop sign so there's a good chance it's OK
carguyinva's Avatar
VA
08-11-04, 01:26 PM   #14
sounds like...
this may be beyond your ability to determine...perhaps it's time to get it hauled to someone for a definitive diagnosis.
both previous posters may be correct...you need the opinion of a pro
sorry, dude...sometimes you're windshield...sometimes the bug
TX
08-11-04, 01:59 PM   #15
things to look at
To see if it is the timing belt with out tearing into the engine you can remove were you cap were you put the oil into you should see a camshaft.Use a flashlight if you have to.
Have a friend try to start and watch to see if cam moves.Or you can take cap off distributer and see if it goes around when you try to start.
Good news is most toyota engines will not self destruct when belt breaks.
ripcurl's Avatar
08-11-04, 02:26 PM   #16
Yep, the previous poster was right, corolla engines are not interference engines according to the following link : http://gates.com/downloads/download_...older=brochure
That link is a gates online catalog, tells you what engines are and are not interference motors and also tells you the recommended replacement period for belts. Quite a helpful resource.
slickshift's Avatar
08-11-04, 08:28 PM   #17
Link
Nice link - PDF too
It's a keeper, thanks ripcurl
