86 f150 starter
Old 08-10-04, 02:26 PM
ilesracing
86 f150 starter
My starter stays running after starting truck, I replaced the soleniod but it still does it where should i look next? I can just put the wire on the terminal and it cranks.
Old 08-10-04, 04:36 PM
Iwould diconnect the connector at the ignition switch and see if it still cranks by itself.If it does something is wired wrong or you have a short to voltage on the starter signal wire.If it doesn't still crank I'd put an ignition switch in it.
