97 Pontiac Grand Am 2.4L Needs Diagnosis!!!
Old 08-11-04, 09:25 AM
OSUcowboys
Exclamation 97 Pontiac Grand Am 2.4L Needs Diagnosis!!!
97 Pontiac Grand Am 2.4L. Have a few questions on it because I have been tricked by these symptoms before.
3 weeks ago, check engine light came on (car was running ok), GM dealer replaced O2 sensor and pack and the car ran fine. A few days ago the check engine light came back on and now the car is starting to jerk inconsistently during acceleration in 2nd-3rd gear and sometimes from take-off.
I have seen plug wires and spark plugs cause this, but also fuel filter. Any ideas on this one and should it have been discovered at the dealer when the check engine light came on.
Old 08-11-04, 09:33 AM
carguyinva's Avatar
it's hard to tell...
...unless you have the code from the first episode. if the codes happen to be the same, i'd say the dealer missed it the first time and owes you something. if the codes are different, and they easily could be, then it's probably coincidental.
the bottom line is that you need to know the code stored in the computers memory associated with the check engine lamp. autozone can give you the code and won't charge anything...post the exact number with letters here and someone will decipher it for you and give you some direction.
Old 08-11-04, 09:41 AM
OSUcowboys
The repair receipt
The repair receipt from the previous episode doesn't appear on the itemized listing, but it does say:
CUST STATES CK ENGINE LIGHT ON
CHECK FOR CODES P133.BANK 1 OXYGEN SENSOR INOP
REPLACE O2 SENSOR REPLACE VACUUM HOSE TO MAP SENSOR
CLEAR CODE
So that all seems in order. I will run up to an autozone tonight and see if I can get the code for this episode. I will post.
In the meantime, any ideas of the engine trouble Catalytic? Sparkplugs? wires? Fuel Filter? Am I way off?
Thanks for the response
