'00 Olds Alero fan problem
Old 08-17-04, 06:50 PM
Question '00 Olds Alero fan problem
Working on a '00 Alero, the heating/cooling fan will only run on High, low and med are dead. What do you think, switch, relay, or otherwise? Thanks!
Old 08-19-04, 03:13 PM
The blower resistor is likely faulty I would change it you should see burn marks on it.
