Unable to lift window
Old 08-17-04, 07:49 PM
Hello,
My electric window lift on the passenger side of my '95 Nissan Pathfinder has gone out. The motor in not operating, however I am attempting to raise the window manually. Does anyone know the technique in order to raise the window of an electric control manually?
Thanks,
Joey
Old 08-18-04, 06:00 AM
carguyinva's Avatar
remove the trim pad...
...on the inside of the door, then disconnect the window from the regulator (that's the part that connects the window to the motor) and the glass will slide up easily...however, be careful not to disconnect the motor from the regulator as it may be under spring pressure and you could lose a finger.
having said that...you really should use a test light and determine if the motor is in fact bad...it could be the switch
Trackbacks are On
Pingbacks are On
Refbacks are On
