'02 pathfinder, water in fuel
djengr's Avatar
OK
08-18-04, 06:33 PM   #1
I have a 02 nissan pathfinder, 40K miles, auto. The service engine soon light came on. Took to Autozone to pull the code. P1140, water in fuel. Filled up with fresh fuel, car runs fine, actually never did run bad. Does anyone know how to manually reset the code on this vehicle.
DJ
Johnc280's Avatar
08-18-04, 08:00 PM   #2
Johnc280
I have never heard of a P-code for water in fuel. First I would take it to another place and have the trouble code checked again before clearing it. Then, if you want it reset just ask them to do it then with the scantool.
Johnny
Desi501's Avatar
08-19-04, 03:41 AM   #3
Yes, a P1140 actually is a water in fuel code. Just refilling the tank is not enough. You need to add a fuel additive to remove the water and change the fuel filter. Then the same guy that read the code can reset it. He may have already done that and it just came back because the problem still exists. Get it fixed before you start having some much more expensive problems.
djengr's Avatar
OK
08-20-04, 08:13 AM   #4
Fyi
Thanks
I added a bottle of "HEET" to the tank (5/8 tank). Change the fuel filter. FYI to anyone the fuel filter is at the back of the vehicle tank tucked above rear differential, not hard to change, spent about as much time trying to find the silly thing. The Autozone will not reset the codes, something about liabilty.
DJ
Desi501's Avatar
08-20-04, 06:03 PM   #5
Posted By: djengr Thanks
DJ
That sounds really fishy. they ought to worry more about the liability of all their incorrect diagnosing to sell parts. Go back another time when someone else is working. You'll never get the same answer twice in that place.
