Changing '99 Explorer Fuel Filter
Old 08-18-04, 07:50 PM
Unhappy Changing '99 Explorer Fuel Filter
Well first off I'll give you the problem. For about a month now I have had a few times where it was difficult to get the truck started. I had to stand on the gas to get it going. After it fired it was ok. I put fuel injection cleaner in it last week thinking it may help the problem. Today I tried to start it and it would only start if I stood on the gas but would stall as soon as I released the pedal. I now will not stay running unless I have my foot on the gas.
I picked up a fuel filter to start there. Hopefully this is the problem. I took off both of the clamps but I can't seem to get the filter free from the line. Is there a trick or is there a tool that I need to relese this?
Also, does it sound like the problem may just be the filter or is it the fuel pump?
Any help will be much appreciated.
Old 08-18-04, 08:49 PM
Johnc280
To change the filter you will need a quick disconnect tool. They are easy to find at almost any part store and usually only a couple of dollars.
I don't think your problem is either the filter or the pump. It sounds more like an air flow sensor, idle air control problem, large vacuum leak etc. When you push the gas pedal down you are actually just opening the throttle body to allow more air to your engine....the computer controls the amount of gas you get with the fuel injection. (simplified explanation)
Check these few things and then post your findings (if you can't get the tools or equip you may want to take it to a repair facility for a diagnosis.)
1. What is the fuel pressure while you are trying to crank the truck.
2. Are you getting spark?
3. Are there any trouble codes stored?
Good luck,
Johnny
Old 08-19-04, 05:56 AM
hogfan's Avatar
It sounds just like a Idle Air Control Valve but You might need to clean the throttle body also.
Old 08-19-04, 01:05 PM
Desi501's Avatar
That will have absolutely nothing to do with a hard start condition. Sounding like a fuel pressure issue but needs to be tested further.
Old 08-19-04, 05:36 PM
TOPTECH's Avatar
How wrong you are! If you hold the throttle down part way and the vehicle starts and runs ok, but shuts off as soon as you release your foot, it is almost surely the IAC valve. These vehicles are famous for problems with these valves. I have replaced dozens of them on late model Fords.
Old 08-19-04, 07:37 PM
Desi501's Avatar
I'm well aware of the problems with Ford IACs
It won't give you that symptom.
