Honda Pulls to the Right
Hello all.
My 97 Honda Accord pulls to the right pretty bad. There's also a little bit of "jerk" in the steering wheel. We don't drive the vehicle often, but I don't remember hitting anything like a pothole--the problems just seemed to appear. The problem occurs at both low and highway speeds. Tire pressure is fine. Aside from the pulling and the "jerk", there are no other symptoms (no noise or anything).
I'm taking the car to a shop on Monday, but I'd like to know what sort of things I might expect. I suspect it's more than a simple alignment issue.
Thanks
Thanks
I'm leaning towards a bad rf tire.Swap the front tires side to side and drive it again.If the pull stops or goes to the left side it's the tires.If not you may have suspension damage or worn parts.
