firing
Old 08-20-04, 02:42 PM
firing
1994 olds bravada could anybody tell me the order of firing of this motor?have a miss that wasnt there after tune up
Old 08-20-04, 03:28 PM
1-6-5-4-3-2 There you go.
Old 08-20-04, 04:56 PM
how do i know where the wires go on this order?what is the starting point?
Old 08-20-04, 05:17 PM
well you may have to pull number one plug and bring it up on tdc on the compression stroke to see where the rotor is pointing to determine number one position as it may have been moved, factory setting was usually the furthest front terminal towards the driver side on the cap for number one and then went in a clockwise direction for the firing order.
if it runs but is missing you may have crossed a couple of wires or broken a sparkplug is also a possibility number 3 comes to mind as it is commonly cracked when installing as it is the hardest one to usually change.
