car will not stay on
Old 08-21-04, 11:03 AM
jdcuzmar
Unhappy car will not stay on
I have a 2000 Ford Taurus V6 3.2L That the motor will not stay on unless I accelerate the gas. However, after it runs for 30min the problemm will vanish.
The battery is good, the belts are all secured, and the only thing I can think of is the alternator. How can I check this?
Any help would be appreciated!
Old 08-22-04, 06:03 AM
D
It is not the alternator.If the service engine soon light is on have your codes read and post the code # here.Try cleaning the throttle body with carb cleaner and an old toothbrush.While you are at it clean the IAC valve also see what happens after that.
Old 09-07-04, 07:46 AM
jdcuzmar
Unhappy
I tried cleaning the throttle body and the IAC valve, but that did not work. Any other suggestions??
Old 09-07-04, 12:55 PM
sdsdogg2's Avatar
Ford does not recomend cleaning their throttle bodys due to a coating inside. Does the car seem to run rich or does it idle ok?
Old 09-07-04, 03:07 PM
D
Have you checked the fuel pressure yet with a guage and compared it to the specs in your service manual?Try cleaning the MAF sensor also just in case it has oil on it.How many miles on the car?
Old 09-08-04, 10:05 PM
squidgrouch
More than likely, the iac valve is faulty. Have an assistant start the vehicle. At the same time, tap on the valve with a very small hammer, or something like that. Engine speed will likely change. Use a factory part.
Old 09-10-04, 04:58 PM
slicker
gotta agree. ford can not design a perfect iac valve. take the valve off and shine a flashlight thru one of the holes and see if you can see light thru the other hole. alot of times the plunger inside sticks.
