no cruise control ???
Old 08-23-04, 04:18 AM
I have a 1998 Ford Windstar. I turned on the cruise control and all was fine until I tried to set acceleration and nothing happened. Now when I press the "on" switch on the steering wheel - the light on the dashboard does not even come on and I don't have cruise control? Is there a fuse that might be blown or something else? Thanks.
Old 08-23-04, 12:14 PM
It could be an in-line fuse - ie., one that's not contained in the main fuse block of the car. It could also be a vacuum leak - like a bad or disconnected vacuum hose going to the cruise control servo.
Bob
Old 08-23-04, 02:57 PM
lorax123
Could just be the contacts at the steering column are dirty and need to be cleaned. That is if you're CC buttons are on the steering wheel.
Old 06-19-06, 09:51 AM
Same issue. . .
I have the same exact issue with my 2001 Windstar.
Did you ever resolve this issue?
Thanks.
Robert
