99 cadillac escalade
Old 08-23-04, 01:39 PM
otel800
Exclamation 99 cadillac escalade
I am leaking antifreeze, when i look underneath suv i see it dripping from transmission, can it be coming from motor??
Old 08-23-04, 03:55 PM
Sounds like it may be the intake manifold gasket leaking.It may be in your best interest to pressure test it or pay someone to do a pressure test usually a fairly cheap test.
Old 08-23-04, 04:02 PM
otel800
Unhappy
is that an expensive project to fix
Old 08-23-04, 04:16 PM
Depends if you do it or pay someone.The parts are not that high but it does involve some labor time.If you do it change the oil when you are done.
Old 08-23-04, 04:20 PM
otel800
what exactly does the presure test do?
Old 08-23-04, 04:25 PM
otel800
Unhappy
does that require to take half the engine apart?
Old 08-23-04, 05:29 PM
Desi501's Avatar
The pressure test will bring out the leak so it can be diagnosed precisely. As for the repair, yes, you do have to disassemble a good chunk of the engine. The intake manifold has to be removed.
