95 Caravan-cooling fan relay switch where is it?
mhastie's Avatar
08-27-04, 07:29 PM   #1
mhastie
We have a 95 Dodge Caravan and need to know how to find the cooling fan relay switch, can anyone help explain how to find this ? Fan does work, but will not come on, Did the computor code on the van and its 35 -fan relay switch. Would really appreciate the help. : It haas a V6 3.0L Engine
bejay's Avatar
08-27-04, 08:34 PM   #2
if it is a fan relay module it is usually mounted low on drivers side inner fender close to the radiater and usually requires you to get underneath the vehicle to access it.
if it is just a standard relay it is likely in the underhood fuse or relay box.
not sure what year chrysler started using the module type relay so not sure which one your van will have.
