94 Ford F-150 tranny slippage
Old 08-30-04, 03:18 PM
A
als206
I purchased a 94 F-150 back in June The milage on the truck is 57K I've been having problems with the trans slipping in and out of overdrive and in and out of third gear. I don't think the fluid or filter have ever been changed. What do you think?
Old 09-01-04, 11:00 AM
carguyinva's Avatar
by all means...
...have the fluid and filter changed and be sure that the fluid level is correct after the service has been performed. but...if it truly has been "slipped"...then some damage HAS ocurred and will eventually have to be addressed, probably by overhaul. ford also has some issues with OD and lockup which may be what are referring to...hard to say without a road test. a good trans shop for an evaluation may be wise at this point
