battery terminal corission
tom2002's Avatar
08-31-04, 09:39 AM   #1
Does anyone out there have a quick tip on how to remove corrosion from car battery terminals? I need to chaange the battery and can't seem to get the corroded terminal removed (nut/bolt not moving). I'v heard that spraying Wd-40 or dousing it with Coke does the trick??
thannks to add in advance for responding...
toyotaman11769's Avatar
08-31-04, 09:45 AM   #2
Hot water, plain and simple.
goldstar's Avatar
OH
08-31-04, 10:25 AM   #3
Baking soda will neutralize the acid. Work it around the terminal with an old , damp, toothbrush. Then the hot water treatment. You may still need a battery terminal puller and need to cut out the old bolt and replace it.
weekendwarrior0's Avatar
09-02-04, 01:42 PM   #4
I have used Coke, it works!
