Location of voltage reg on 85 ram van??
Old 08-31-04, 01:01 PM
Salmonslammer I
I am 1k miles from home right now and my alt or volt reg has took a poop. Can anyone give me the location of it???? It's a 318. All my manuals are at home. I metered out the battery and it was at 9.6v running at 1500 RPM. Im off to the auto parts store to get alt tested right now..figure I might as well do both.
Old 08-31-04, 01:44 PM
Davejb's Avatar
If I remember correctly (and it is highly likely that I might not) I thought it was part of the alternator.
Old 08-31-04, 05:27 PM
Salmonslammer I
I thought that too... I had a buddy of mine go to the house and get the chiltons.... In the wiring scematic it shows an external VR....yet I can't find it..
Old 08-31-04, 05:47 PM
McDann
The voltage regulator should be located on the firewall near the computer.
If this is EFI the alternator is controlled by the computer.
Old 08-31-04, 06:28 PM
Desi501's Avatar
Correct, the regulator is in the computer for all fuel injected vehicles, Chrysler that is.
Old 09-01-04, 06:12 AM
Salmonslammer I
It's not efi.....does that still make a difference?
Old 09-01-04, 08:29 AM
E
As I remember the voltage regulator is located high on the firewall slightly to the left of center looking at the engine with the hood open. Three bolts hold it and when I changed mine there were 3 different sized bolts. It may be buried under some wiring. The bolts are important to get tight as they provide a ground.
Old 09-06-04, 05:22 AM
Salmonslammer I
Found it.......Passenger side, behind the wiper motor, buried under a bunch of wiring harnesses.... Thanks again!!
