How to bleed breaks on a 4x4?
stac's Avatar
09-02-04, 12:56 AM   #1
stac
I have a 91 chevy 1500 1/2 that needs the breaks bled. i want to do them myself. how to do that? any suggestions would be greatly appreciated.
thanks!
stac
toyota/lexustec's Avatar
09-15-04, 08:48 PM   #2
toyota/lexustec
bleeding brakes
have some one in the vehicle to pump the brake pedel while you open the bleeder screwa for each wheel. have the person in the vehicle push down the brake pedel slowly while you open up the bleeder screws when the pedel is at the bottem close the bleeder screw and have the person in the vehicle pump the pedel until they feel pressure then repeat the procedure untill you have a steady stream of fluid comming from the bleeder after every stroke of the pedel repeat for all four wheels bleeding sequence is RR LR RF LF make sure you keep the master cylinder full of brake fluid
