window seal 1987 olds cierra
Old 09-07-04, 12:21 PM
K
Where can I get door to glass horizontal outer glass seals. Base of window. All 4 door windows. 1987 cutlass cierra.
Old 09-07-04, 02:45 PM
D
Have you tried the dealer?Why do you need all 4?
Old 09-13-04, 07:50 PM
K
They are dry rotted. Water is getting inside the door. I am restoring for hobby.
Old 09-14-04, 04:11 AM
D
Replacing those seals will not keep water from entering the door.There is a plastic water deflector and drains in the door so water does not get the door panel wet or fill up with water.
Old 09-14-04, 04:17 AM
carguyinva's Avatar
those pieces...
...that go at the top of the door where you rest your arm when the window is down are called belt mouldings. they may be hard to find given the age, but check the dealer. they also require that you remove the glass to get to the screws that hold them in...they are time consuming but look really nice when done
