Fuel Injectors, Filter, or Fuel Pump
Old 09-07-04, 08:42 PM
C
carlos351967
Red face Fuel Injectors, Filter, or Fuel Pump
1993 Cadilac Fleetwood. My Cadilac stops injecting fuel every so often. Any help? Thanks.
Old 09-08-04, 09:43 PM
K
keagle
Had three injectors go bad on a 94 thunderbird. Started blowing white smoke real bad! Thought I'd blown a head gasket or somthing. Don't know if this happens all the time, but that's my experience with injectors. Have been told on T-birds, when injectors go bad, computer goes bad also...somthing to think about. Good luck!
Old 09-09-04, 04:42 AM
carguyinva's Avatar
proper diagnosis...
...is performed when the problem actually is ocurring. loss of injection (if that's what is really happening) can be caused by several things. if you can pinpoint a commonality it will help someone find your problem. does it do it cold or hot? does it do it on damp days? does it happen when you are accelerating or maybe even turning?? does it start right back up or do you have to wait for a time? finding that common thread will help a tech be able to reproduce the problem and zero in on it's cause.
