09-08-04, 07:57 AM
91 Chev C1500 Fuel Pump Relay
Haynes Manual states "at normal opr. temp. and at idle, disconnect the fuel pump relay, if the engine stops, the oil pressure switch is faulty. My truck does die. My question is: Can this cause the engine to die on cold start up, then idle irradically? thanks bunches
VA
