timing on a 1993 grand prix, anybody have a clue?
Old 09-11-04, 07:17 PM
K
karashfre2004
i need the engine timing specifications for a 1993 grand prix 3.4L v-6
Old 09-11-04, 08:21 PM
B
ignition timing is not adjustable.
if you are reffering to the timing belt suggest you buy a manual and the appropiate tools to get the camshafts aligned correctly you will have to remove the upper intake and valvecovers the special tool bolts on under the valvcover to hold the cams in the correct position and you may just want to take it to a shop as by the time you invest in the tools needed to change the belt yourself you are not saving anything.
Old 09-12-04, 05:16 AM
D
I really don't advise a diyer to attempt a timing belt on that engine.If you have a different engine with a chain fine go for it.I have seen professional techs go nuts trying to get them timed properly(the vin x timing belt engine).
