key stuck in ignition
Old 09-13-04, 07:14 AM
1995 MERCURY MYSTIQUE. The key won't go into the lock position acc. start and run position ok.Anyone had this problem?Thanks for the help.
Old 09-13-04, 08:06 AM
keagle
I just recently had this happen to a 1990 Mazda 929s. The ignition cylinder was worn just enough that the key had to be held in a certain position to remove easily. My particular case; I had to push in on key, then lift up, then turned to lock easy. Purchased new cylinder and working fine. Good luck.
Old 09-13-04, 07:54 PM
Try pulling the shifter towards park while pulling on the key. If it removes, transmission linkage is out of adjustment with shifter lock. I just fixed an 87 olds.
Old 09-15-04, 08:22 AM
jatco's Avatar
Try as kklukas mentioned. This was a similar situation in my wife's old '85 GP. If the gear selector wasnt in Park, you couldnt remove the key. (safety issue).
Trackbacks are On
Pingbacks are On
Refbacks are On
