Fuel Injector '96 Sunfire
Old 09-13-04, 10:32 AM
Trying2Help's Avatar
Question Fuel Injector '96 Sunfire
Friend has a '96 Sunfire and says injector is leaking. Just wondering if there is a way to stop the leak or how hard is it to replace a injector, any special tools or tips?
I have turned quite a few wrenches, but never replaced injectors before, so thought I would get your advice before going over to see what is "really" going on.
Old 09-13-04, 02:52 PM
Desi501's Avatar
Is it TBI or ported? Is it leaking through the injector itself or one of the O rings.
Old 09-13-04, 03:26 PM
Red face
Darn it Desi, I haven't even looked at the thing yet so I don't know if it is TBI or ported. I believe it is leaking at an o-ring as he says he can see and smell the gas. Can you just replace the o-rings?
Maybe I will have to go look at the thing and see what I see......
Old 09-13-04, 04:50 PM
Desi501's Avatar
The nozzel is exposed on TBI so it could be comong right out the nozzel. There really isn't any O-rings that fail on those. If it's ported, it has an O-ring at the top and the bottom. The bottom one mainly seals vacuum but the top one seals fuel. That's not hard to change. You just have to get access to the rail and lift it up to sneak the injector out from under it. Look at the leak closely. Dry it completely before having someone turn the key on so you can see where it originates. Sometimes the seams of the injector itself will leak. In that case you have to replace the injector.
