'95 Continental W/S Wiper Park Position Problem
Old 09-14-04, 10:03 AM
F
frankswsj
W/S Wipers park 6-7 inches above where they should - sometimes all the way up on windshield. Is this a W/S Wiper Motor problem ? Ford says that if you replace motor, you must also replace Arm and Bracket Assembly - is this necessary or just a way to increase profits ? How and what do I check to find out what to do ? Thanks for your help.
Old 09-15-04, 03:47 PM
D
Most likely a motor problem but it could be the switch also.If Ford says it needs the other parts it probably does the motor could be updated or consolidated and requires extra parts.
