Fuel Cut Out
Old 09-16-04, 07:39 PM
jrodcat
Fuel Cut Out
93 Ford Escort, 1.9L, standard. Close to 200K miles, but well maintained. Had an overheating problem but never got "Too" hot. I noticed the guage going up and pulled over. Water pump was leaking so I replaced it. Now it wont start. The light comes on and says fuel cut out... What does that mean?
Old 09-16-04, 07:46 PM
Inertia switch
Yes you have an "inertia switch" that cuts off fuel when the car is bumped
It's in the trunk (I think, I'll check)
You have to pull off a panel (probably marked), find the switch and pull the white button up
This should reset it
Old 09-16-04, 07:54 PM
Well, I was close,
Open the trunk and remove the right side trim panel and push the red button
Old 09-16-04, 07:57 PM
jrodcat
Pushed it, still doesn't start...
Old 09-16-04, 08:07 PM
Disconnect the battery for a minute or 5
Reconnect
Push the red button
Old 09-17-04, 05:32 AM
Did you get the timing set right after you replaced the water pump?If crankshaft or camshaft moved with timing belt off it will be out of time.
