lost, need help
Closed Thread
Old 09-22-04, 03:02 PM
MDMKLM
lost, need help,toyota Pickup
I have a 1992 toyota pickup, 22R engine, 5 speed trans, I broke a timing chain, and bent valves. Had to have head reworked. NOW, engine will crank but will only run a few second. Could this be a vaccum leak on the intake?
Found a rubber grumit under truck, don't know if it came off intake somewhere.
Old 09-22-04, 04:10 PM
Hi
What shape, size and a description of the grommet?
Is the air flow meter hose and electrical plug on?
Ground wire between the plenum runners?
Check eng lite prove out?
Old 09-22-04, 05:33 PM
MDMKLM
The grommet is about 3/4 inch across with 1/2 inch hole, black in color.
all hoses are in place, along with all ground wires, as far as I can tell.
Check engine light goes out when engine is running.
Old 09-23-04, 04:41 AM
the_tow_guy's Avatar
Received 45 Votes on 36 Posts
Any chance the timing chain is off a tooth or two?
Old 09-23-04, 02:50 PM
MDMKLM
Check Cam timing 3 times before puting cover back on. I checked the Haynes Manual and it tells me I have a vacuum leak. Also, I can not find where the rubber grommet came from. I feel like it belongs somewhere on the intake.
Old 09-23-04, 04:35 PM
Is the grommet square shaped?
Could you post a picture?
Did you take the injectors out?
Can you keep it running by giving it throttle?
Old 09-23-04, 07:18 PM
MDMKLM
The grommet is about 3/4 inch across with 1/2 inch hole. NO, I did not remove any injectors, and the engine will not stay running when I give it
throttle.
Old 09-23-04, 07:38 PM
Sounds like a protector that goes around the PCV hose. Won't cause a problem.
That would have to be a hugh leak not stay running with throttle.
Old 09-23-04, 07:40 PM
Is the Dist in right?
Old 09-25-04, 08:17 AM
MDMKLM
I had rotor pointing to #1 plug wire, and #1 piston at TDC when I installed it. Could this be a coil problem?
Old 09-25-04, 09:25 AM
TDC compression or exhaust?
Old 09-25-04, 10:39 AM
When the timing chain broke I highly doubt the coil went bad.
The next thing after the chain broke and bent the valves is it was taken apart and put back together.
Thats where I would be looking for the problem.
Closed Thread
