1989 Nissan pick up wont start
Old 09-22-04, 06:06 PM
T
1989 nissan pickup wont start. v-6, got spark and getting gas.
drove thru water stalled, about 1 hour later started, drove 2 miles stalled again. never restarted. rolls over, back fires thru carb (throttle body) sometimes starts fire. worse when pedal is floored.
ANY suggestions.
Timing belt is good, spark to the plugs, fuel filter bypassed to check
Old 09-23-04, 04:39 AM
the_tow_guy's Avatar
Received 45 Votes on 36 Posts
Pretty good chance you got some water where it shouldn't be. I would start under the distributor cap. After that start checking the various connectors under the hood one at a time. Get a spray can of electrical contact cleaner to clean/dry.
Old 09-23-04, 03:26 PM
T
nissan
thanks, the cap was dry that night, I did spray wd40 in it and wiped it out.
could a valve be bent ? or stuck ?
