nissan micra 1994.sometimes wont start
Old 09-24-04, 08:57 AM
I
irishmoscito
car wont start.Iturn on engine it wont kick over.no rev.could it be the battery or starting motor.
Old 09-24-04, 07:56 PM
could be either
First check the battery terminals
Even if they look OK, loosen and pull off the connections and clean them up
Make sure they are snug when you put them back on
If it's an intermitent problem it's not likely a worn battery, but you should get some voltage readings from it anyway
After that maybe a starter check is in order
Some more info about the vehicle and the circumstances that it won't start would be helpful (after not being started for a day, when it's wet out, just whenever it feels like it, etc.)
Old 09-26-04, 01:36 PM
I
irishmoscito
hi thanks for info.
The problem seems to only happen when it is damp out in the morning.
Old 09-26-04, 04:21 PM
Check the wiring on/to the starter also
Everything must be clean and snug
Look for corrosion, in/on any wiring in these areas (batt. start.)
