fuel pressure drop
Old 09-24-04, 03:16 PM
wayne141
fuel pressure drop
Hi guys, have a 1995 dakota V8. It losses fuel pressure after sitting. Will crank for a long time, then will start when cold or sitting for about 45 min.
I hooked up a fuel pressure gauge, 40psi running(normal according to manual), but will drop to about 5psi within 5 seconds, after I turn off engine.
Cannot find any fuel leaks, I assume its the regulator,. How do i know for sure? Its mounted on the tank. Or could the injectors be leaking? (it doesnt flood after restart, so i dont think thats the case)
Fuel pump sounds normal
Thanx in advance for your help,
wayne
Old 09-24-04, 06:00 PM
B
usually it is bleeding back through the fuel pump check valve and it likely comes as a whole unit such as a fuel pump module.
