1993 ford escort idle problem 1.9l engine
1993 ford escort 1.9l automatic trans. A/C When engine is cold it idles high then idles down like it should.After it gets to normal temp if shut off and start again idles way too high for about 1 min then goes back too normal.Also cooling fan coming on even when engine is cold.It didn't used too come on untill temp 190' or 200'.Thankyou for any info anyone can give me.Also check engine light is on.
