89 Nissan pick up compression
Old 09-27-04, 07:18 PM
T
how much compression should there be V-6 3.0
Old 09-28-04, 04:57 AM
carguyinva's Avatar
according to...
...nissan specs compression should be 128-179 PSI with no more than 14 PSI difference
also...compression should be checked on a warm engine, good cranking speed
(this means that starter should be in good shape and the battery fully charged) with the throttle open.
don't forget to disable the ignition and fuel systems and normally crank the engine thru the compression stroke 4 times...this is easiest to hear if you remove all the spark plugs (also makes it easier for the starter to crank the engine)
Old 09-28-04, 12:08 PM
T
nissan
thanks, I couldnt do it with warm engine, it wont start which is why I am doing this, I get 155-165 lbs per cylinder.
ANY input as to not starting would be great, started for about 5 minutes yesterday but stalled, then wound start again.
all started when I went thru water, died right there, started about 1 1/2 hours later, for about 5 minutes, about 1/2 hour after thats I drove it for about 1 -2 miles died again, didnt start for about 2 weeks til yesterday just before I didnt the compression test. got spark, getting gas, backfires thru carb. filter is off now, timing belt good marks line up on top ??????????
