1992 S-10 runs poorly !!!
Old 09-28-04, 11:49 PM
gtmarko
hello my 1992 S-10 pick up with a 2.8 v6, standard tranny, runs rough at idle and studders when you take it down the road.this all happen at once so i went to the parts store and got plugs, wires, cap ,rotor,fuel filter,then a temp. sensor,ign. module (under the dist. ) and a coil. cleaned: the egr valve,iac valve,and checked the CAT.is OK.can you help me out with my S-10 that`s got me wondering what else to do with it.
Old 09-29-04, 04:00 AM
carguyinva's Avatar
double check...
...your work. if the roughness and studdering started after you tuned it up...then it's most likely something you did. specifically, i'd make sure the wires were on there right and that you didn't crack a spark plug when installing. 2.8's, while a sorry powerplant, are very smooth when right...
Old 09-29-04, 08:16 PM
gtmarko
1992 S-10 runs like crap!!!
i`ve checked for codes and found the numbers 22 & 33 .tps & map sensor,replaced both parts and still it runs rough and studders down the road.could it be fuel,vaccum, electric,or interno?. all i know is that it`s getting really expensive to try and get this to run right
Old 09-30-04, 03:10 AM
it could be alot of things I would check all vacum lines around the intake to make sure they are not leaking also remove the vacum line from the map sensor start engine and make sure it is getting good vacum at idle to the map sensor they are known for clogging up the map sensor vacum port.
before you throw anymore parts at it you should see a shop for a diagnostic as it could be alot of things and most shops have the equipment to check the vehicle out and find out the cause of the problem, for what you have paid out for parts that didnt fix the problem you would of been way ahead if you did this to begin with.
Old 09-30-04, 04:17 AM
carguyinva's Avatar
the map and tp...
...definately need to be diagnosed because this is where your problem most likely lies. just because it has a code in the ecm memory, doesn't necessarily mean that the associated part should be replaced. i have to agree with bejay...you'd likely be ahead had you taken it to be diagnosed. you'd be way ahead if you own a DVOM and can follow the diagnostic trouble tree for those codes...beginning with the lowest number first. the map and tp circuits are electrically related and the diagnostics will zero in on the problem.
Old 10-04-04, 05:34 PM
gtmarko
s 10 runs like crap!!
i was told that the bad fuel pump could make the truck run erractic when at idle or going down the road. what do you think? need help with my poor S-10
Old 10-04-04, 05:51 PM
Desi501's Avatar
We went through all this same stuff on the other forum. I know you checked everything at the MAP but if you cleared that code and it came back then something is setting that map code and you have to get to the bottom of it. If it doesn't reset, then your barking up the wrong tree with that.
Old 10-04-04, 06:51 PM
gtmarko
there are no codes, i think it`s fuel related
Old 10-05-04, 03:46 PM
Desi501's Avatar
It could be. You'll have to put a pressure gauge on it to find out. Sometimes I tape it to the windsheild while I road test it so I can see what the pressure does when the problem occurs.
Old 10-14-04, 02:03 PM
gtmarko
s-10 runs poorly
all fix it was the fuel pump sending unit runs great thanks to all
