1992 accord
doitnewf's Avatar
09-29-04, 04:00 AM   #1
doitnewf
1992 accord
Right side front caliper is sticking.
Took off caliper cleaned up moves freely by hand.
Put back on & still same
Someone said it could be the flex hose
How can I check to see if it is the flex hose
Cheers
JP
carguyinva's Avatar
VA
09-29-04, 04:03 AM   #2
try this...
...get it "stuck" by applying the brakes and then jack it up, remove the wheel and crack open the bleeder screw on the caliper. if you get a little blast of fluid and the caliper frees up, the hose is collapsed inside...replace it. if it still stays stuck, the piston is seizing in the caliper bore and you need to replace the caliper. as added insurance...whatever you do to one side, there's wisdom in doing to the other side.
doitnewf's Avatar
10-03-04, 03:26 AM   #3
doitnewf
Thanks for the help!
It was the flex hose....
New hoses..............everything AOK!!
Cheers
JP
