91 Olds Caliper Bracket
Old 09-29-04, 07:22 AM
fourstar10
Any suggestions on how to get the caliper bracket off? The calipers came right out with a regular bolt, But the bracket that covers the rotor and that holds the caliper won't budge. I broke one torx 60 bit already. I've tried to heat the bracket and have saturated the bolt with PB Blaster to no avail.
Any Help?
Thanks for looking
This is a cutlas supreme int. with four wheel disc brakes.
Old 09-29-04, 11:31 AM
B
suggest buying another socket prefferbly an impact socket and using an impact wrench if available or a large breakover bar these bolts are always hard to break loose as they have locktight on the threads and it isnt uncommon for the cheaper brand sockets to break.
