turck keeps stalling
Old 10-02-04, 05:07 PM
harllo
hello out there need help i have a 87 chevy p/u truck 350 engine my problem is when im coming to a stop just before the stop i take my foot off the gas and start breaking my truck stalls i start it back up and get ready to stop again it does the same thing i put a carb on it it runs fine in park it has a tune up complete what could be the problem?
Old 10-03-04, 06:05 PM
Maybe a vaccum leak...
inside the brake booster. It's against the firewall just behind the master cylinder. Try disconnecting the vaccum line and capping it off (seal it off very well), start the engine, then stepping on the brake pedal. If the truck has no change, you found the problem.
IF you have to drive it this way, you should know that the brakes will take a lot more pedal effort to stop.
If it is the booster, you'll need to replace it, I don't think they can be repaired. BTW, my father's truck had the same problem.
Old 10-03-04, 08:08 PM
might try disconecting the egr valve vacum line and driving to see if the problem still occurs as an egr valve that is slow about closing will cause the vehicle to die when letting off the gas.
a carb that is not adjusted correctly could cause the same problem.
Old 10-04-04, 04:55 PM
harllo
i capped off the vac from the booster and it still did the same thing it dont shut off as soon as i put the truck in gear seems like when i start moving and then when i go to stop i dies out when i brake could it be a starter, distributer shaft?
Old 10-04-04, 04:58 PM
harllo
when that eng was put in the truck the egr was not used and the carb was replaced what els could you think of might be the problem?
