i am going to try to pin stripe for my first time anybody have any hints tricks words of advice ,also when cutting at different stops do you cut long and what is the best way to cut.thanks in advance andy
The pinstripe should be run the length of the vehicle then cut to make a break between panels.That way you can make sure it's right before you rub it done to the paint.Pinstripe can be moved/adjusted before rubbing it down for proper adhesion to the paint.
