ac compressor turns off under light accel
gilbroyles's Avatar
10-04-04, 09:52 AM   #1
gilbroyles
1994 Jeep Grand Cherokee - 5.2 L V8
My jeeps air conditioning cuts out under light acceleration. Is there an adjustment to make the cutout occur at a higher rpm? Is there a way to bypass the cutout mechanism?What part would have to be replaced to cure this problem?
Many thanks for your assistance.
Regards
Gil
Desi501's Avatar
10-04-04, 03:43 PM   #2
Your likely being cycled by the low pressure cycling switch. That's what it's there for. Your either low on refrigerant or there is a restriction in the system. Most likely a refrigerant leak. jeeps are notorious for evaporators. Bring you BIG wallet for that one.
AutoDoc's Avatar
10-06-04, 01:01 PM   #3
if not the low presure switch you are probobly losing vacuum and the blend door is closing
