Can a fuel gauge sender be fixed?
Old 10-04-04, 10:44 PM
Mike Burdick
Hi,
Can a fuel gauge sender be fixed? Well...this unit is on a Massey Ferguson 65 tractor and this category was as close as I could get.
The problem is that the resistive wire is broken and I was wondering it anyone knew where I could get some replacement. The gauge is 30 to 240 ohms.
Thanks in advance…Mike
Old 10-05-04, 06:15 AM
I've never heard of resistive wire. Are you sure its not just normal wire? Or you talking about wire inside the sending unit itself?
Old 10-05-04, 06:49 AM
Mike Burdick
It's the wire inside the sending unit. Basically it's a variable resistor where, in my case, it has values from 30 to 240 ohms.
The reason I need to repair it is because the manufacturer doesn’t make a replacement anymore.
Old 10-05-04, 01:34 PM
I would not try to repair it. One spark from a bad repair could send it and you to M - F heaven.
Why not a universal replacement. J.C. W*** the Chicago auto parts catalog house has a sender for $ 17. You may need to buy a matching gas gauge but should be able to solve your problem relatively easily.
Old 10-05-04, 03:40 PM
Desi501's Avatar
I agree with Goldstar. There's nothing you can do if that resister gets a break in it. There are many universal type floats that can be adapted to that tank. Try the marine suppliers also. Just find something that matches the tank depth.
