'87 351 windsor idle too low - adjustable?
Old 10-07-04, 02:58 AM
R
redman1118
Trying to help someone far away ....Rebuilt Carb installed; now idles too low ,,is there a throttle stop set screw normally (assume it's a Holly or Carter oem carb) or is the idle set via the trucks computer and can't be manually raised?
Old 10-07-04, 08:39 AM
A
Yes there is a curb idle adjusting screw right by the linkage hook-up
Old 10-08-04, 04:01 AM
R
redman1118
thank you autodoc ......problem fixed
