Engine pings..2004 Ford Ranger
gidawes's Avatar
10-07-04, 01:00 PM   #1
gidawes
Engine pings..2000 Ford Ranger
I have 2000 Ford Ranger 6cyl with 28,000 miles on it and it pings when going up a hill. I use a fuel additive at every fill up, it doesn't matter what brand of gas or if I use unleaded vs premium. It actually sounds like a diesel engine when I am going up any hills, that is the only time it pings. What could be causing this?
thank you......glenda
Desi501's Avatar
10-07-04, 01:06 PM   #2
Isn't this truck under warranty?
gidawes's Avatar
10-08-04, 11:18 AM   #3
gidawes
engine pings
Posted By: Desi501 Isn't this truck under warranty?
No....it's 4 years old and I am the 3rd owner.
Desi501's Avatar
10-08-04, 04:55 PM   #4
Posted By: gidawes I have 2004 Ford Ranger 6cyl with 28,000 miles on it and it pings when going up a hill.
Posted By: gidawes Quote:
Maybe I'm missing something here....Are we talkin "time travel" or what? 2004.....4 years old????????
Davejb's Avatar
NH
10-09-04, 06:15 AM   #5
The title of your post indicates the truck is less than a year old
"Engine pings..2004 Ford Ranger "
gidawes's Avatar
10-09-04, 12:12 PM   #6
gidawes
You are right........Sorry guys I had a brain glitch!! It is a 2000 Ford Ranger with 28,000 miles on it.
glenda
davo's Avatar
10-09-04, 01:22 PM   #7
Is the check engine light on?If so have Autozone check the codes but don't buy anything yet.
Desi501's Avatar
10-09-04, 04:12 PM   #8
Follow Davo's advice. You may have an EGR problem.
bejay's Avatar
10-09-04, 07:11 PM   #9
you didnt state what size engine you had but there is a tsb on sparkknock for the 3.0 liter v6 might want to see your dealer to see if it applies to your vehicle tsb 00-24-8 and what the repair may require.
davo's Avatar
10-10-04, 05:26 AM   #10
Try leaving the fuel additive out for a couple tanks it may be the cause of the problem.
gidawes's Avatar
10-14-04, 12:07 PM   #11
gidawes
Posted By: davo Is the check engine light on?If so have Autozone check the codes but don't buy anything yet.
no engine lights on.
gidawes's Avatar
10-14-04, 12:08 PM   #12
gidawes
Posted By: davo Try leaving the fuel additive out for a couple tanks it may be the cause of the problem.
OK will try it and see what happens.
thanks......glenda
gidawes's Avatar
10-14-04, 12:24 PM   #13
gidawes
Posted By: bejay you didnt state what size engine you had but there is a tsb on sparkknock for the 3.0 liter v6 might want to see your dealer to see if it applies to your vehicle tsb 00-24-8 and what the repair may require.
sorry can you splain??? tsb, sparkknock??? yes it is a 3.0 liter v6.
glenda
bejay's Avatar
10-15-04, 03:19 AM   #14
technical service bulliton issued by ford they will usually issue a bulliton for a known problem or customer complaint and what needs to be done to correct the problem or complaint this aids dealerships and technicians in repairing the vehicles problem.
sparkknock is another word for pinging.
gidawes's Avatar
10-15-04, 11:20 AM   #15
gidawes
Ok....thanks for the explanation........glenda
TOPTECH's Avatar
WV
10-16-04, 01:26 PM   #16
This TSB will help with the spark knock, but it will not eliminate it. Sorry, you have a 3.0L, thats why you are the third owner of a vehicle with such low milage. Unfortunately, all you can do is live with it or get ride of it. You will otherwise spend a lot of money, and deal with a lot of frustation for nothing.
gidawes's Avatar
10-20-04, 11:11 AM   #17
gidawes
Thanks Terry....it was my Dad's and he gave it to me so I can't really complain. I was concerned that something was wrong with it. If I let it go will it do any damage to the engine?
thanks......glenda
carguyinva's Avatar
VA
10-20-04, 11:25 AM   #18
quite possibly...
...detonation (pinging) most definately can cause damage...at the very least it will damage the connecting rod bearings...the worst case is broken piston(s).
