89 chevy berretta
Old 10-07-04, 04:39 PM
otel800
Question 89 chevy berretta
need to know how to change ignition switch??? well i found out how to change switch and found out it was not the switch. There are some teeth looking piece inside that makes it turn on and off, well it looks like it is broken in half does anyone know if i need to just replace that piece or the whole streeing column? The reason for all this is because the car turns on but does not turn off, it stays onand I need to disconnect the battery to turn it of.
Old 10-07-04, 10:32 PM
z999
You have taken off the ignition switch and steering lock ?
Then you should be able to turn off the car with a blade screwdriver.
Old 10-08-04, 04:08 AM
D
Price a used column it is much easier to change.There are lots of little parts inside a column and some special tools that may make just changing the gear not worthwile to you.At this point there may be something else that caused it to break and if you miss it you start over again.
Old 10-08-04, 02:02 PM
otel800
89 chevy berreta
ihave installed new ignition lock but now i can not remove key from cylinder?
