1989 plymouth voyeger
Old 10-07-04, 08:49 PM
bear3646
Question 1989 plymouth voyeger
i have brake problems i changed the master cylinder and brake booster but still have no brakes i blead them get good brakes untill i start up my van then no brakes help please could there still be air in the lines
Old 10-08-04, 04:25 AM
the_tow_guy's Avatar
Did you bench-bleed the master cylinder before installing it? Should have been directions for doing that in the box with the cylinder.
Old 10-08-04, 01:59 PM
bear3646
reply to tow guy
yes bench blead it new but leaks a little out the back could it be a bad one i was also told to open all bleeders and just keep filling up the master cyl i get good brakes untill i start it up i have vacume when i check the booster it psssss out air so its holding vacume still need help do i have to take out the switch on the valve below the master cyl ??
Old 10-08-04, 02:07 PM
If it leaks it's junk go get another one.Buy a new not rebuilt this time.
Old 10-08-04, 02:09 PM
bear3646
Davo
thanks ill try that im so mad at that van lol
