95 mustang a/c
Old 10-09-04, 06:18 AM
d561139
Question 95 mustang a/c
thank you taking my ?
i have changed the hose assem. on my a/c my question is how much a/c oil do i put back in the system ?
thanks
Charlie
Old 10-09-04, 10:55 AM
the_tow_guy's Avatar
Received 250 Upvotes on 202 Posts
Here's some other question you will need to answer:
1. Did you replace the receiver/dryer?
2. Do you have the necessary equipment to evacuate the system and then service it?
Old 10-09-04, 04:16 PM
Desi501's Avatar
It also depends on how that failure occured. If that hose broke or released the refrigerant all at once, it took a lot of oil with it. If it was just a slow leak and doesn't show much oil residue and you changed the accumulator also (which you should have done), I would add a couple onces. If it had a sudden "dump" of refrigerant, I'd add more like 4-5 onces.
