Check Engine Light
Received 0 Votes
Check Engine Light
97 Saturn SL2, 4cyl., Sedan, 80,000 Miles.
I purchased this car a few months ago and have just recently noticed that the check engine light does not turn on. I checked with the OBD scanner and it says "Error- No link". I then replaced all of the bulbs under the check engine light and checked for faulty wiring and the assembly line data link connector, and the computer command control system. Everything appears to be ok, yet the light will not turn on. The scanner also is still giving me the error message. Any ideas on what could be causing the problem or how it can be diagnosed? Thank you.
Received 0 Votes
Check all the fuses under the hood.On the diagnostic connector pin #4 must read ground,pin#16 must be battery voltage,you should not read battery voltage or ground on pin#2.If all checks good you can try disconnecting the abs module and see what happens.Let us know the outcome.
Received 0 Votes
Re: Check engine light -saturn
Thank you for giving me your suggestions. I checked all of the fuses and they are working. The pin #4 reads ground, pin #16 was orange and works to serial data (PCM- according to Saturn wiring diagram). Pin #2 is purple, but does not specify to where it is connected. Also, the car does not have ABS. According to the diagram, the engine light and the connectors are not directly connected. Why is it possible that they ar-e both not working at the same time? Thank you for your help. I appreciate it.
