alternator/water pump belt for 97 mazda protege
Old 10-11-04, 05:54 PM
duanew
I'm having trouble keeping this belt on my car. I have put 3 new belts on in less than 2k miles. Once it starts squeeling, it soon breaks. I have checked the tension, applied belt dressing, and still I have this problem. Is this something common with this car? It has approx 100k miles. Any help would be welcome.
Thanks
Old 10-11-04, 07:01 PM
Desi501's Avatar
You have an alignment issue your not seeing. Examine it very carefully looking for any pully that is not in perfect alignment or a pully of tensioner that is worn and being pulled at an angle. This will cause the belt to migrate to the side and eventually come apart/off.
Old 10-12-04, 04:30 PM
duanew
Thanks for the reply. I'll have to inspect it again. Would this also cause the belt to squeel?
Thanks
Old 10-12-04, 05:59 PM
Desi501's Avatar
It could. A bad spring tensioner could also do that.
