Daytime running lights stay on after truck is turned off
mikeln's Avatar
10-11-04, 07:12 PM   #1
mikeln
i have a 1997 chev.1/2 ton pickup. the daytime running light stay on after truck is turned off. have to pull relay at fuse box under dash to get lights off.the relay makes a bussing noise. replaced with new relay, still has noise, lights will turn off when i turn key off. I can push parking brake one click the bussing stops.daytime running lights are off. need help finding problem thanks
jatco's Avatar
CANADA
10-13-04, 08:20 AM   #2
Not quite sure how the setup is on your truck, but on my car, the DRL comes on/off when the hand brake is pulled/released. The DRL is generally controlled by the brake....not the headlite switch. You might have a bad contact at the Parking Brake?!?!
AutoDoc's Avatar
10-13-04, 10:02 AM   #3
it is most likely the DRL module
it is located behind the left side of the instrment panal
mikeln's Avatar
10-14-04, 11:07 AM   #4
mikeln
lights
thanks i will replace the DRL module.
