92 escort is UNdrivable
Old 10-13-04, 12:52 PM
Lisayumi
Hi, my car is undrivable.
I took my car to the mechanic about 1.5 months ago to do the pressure test for the coolant, but they didn't find the leak.
Now, when I drive for 5 min. HOLY smoke!! the car is all fogged up! and the heat is really high! Could that be the leak from a heater or something???
Please somebody help me... I'm desparate!
Old 10-13-04, 02:23 PM
You have a leaky heater core. You should also notice the sweet smell of the antifreeze and dampness of the carpet on the front passenger side floorboard. You'll have to replace the heater core.
Old 10-13-04, 03:34 PM
heater core
I am with that heater core theroy most heater cores are a PITA to replace.
Old 10-13-04, 03:46 PM
I with yas on the heater core
On these guys the dash must be removed
Takes a lot of time
PITA
Old 10-13-04, 09:24 PM
A good and cheap temporary(or permanent) solution is bypass the heater core until you fix it or pay someone several hundred dollars to do this PITA job. You'll just have to live without any heat and heated defrost. At least it will get you back on the road.
Old 10-13-04, 10:17 PM
That'll work but...
You wouldn't be fogging up your interior if you hadn't turned on the defrost/heat meaning you'll need it again soon...it's only gonna get colder
I'm thinking safety here
---NewEngland Boy
From The Land Of Foggy Frozen Things Where Bypassing the Heater Core in October is a Bad Thing
Old 10-14-04, 05:59 AM
Desi501's Avatar
Sounds like you could also use a different mechanic. No excuse for not finding that.
Old 10-14-04, 07:50 AM
Unfortunately, this is a major job, and paying someone to do it will cost more than the car's value
http://www.50stangs.com/techarticles/heatercore.html
that's not on an escort, but it details how much work is involved and has pictures too.
if you're handy with a wrench and have a lot of patience, and live where it gets real cold, I'd brave fixing it yourself.
Old 10-14-04, 03:07 PM
Lisayumi
Thanks a lot guys!! Yeah, I found out last night that it might be the heater core -- I have to replace it!! and yeah, probably gonna cost couple hundreds! I'll on the website--thx a lot! you guys are awesome!
I have to start to walk to work now-or I'll be late~~
Thx aGAIN!
Old 10-14-04, 03:37 PM
as mentioned, if this is your sole means for transportation, you can simply bypass this heatercore by connecting the two heater hoses that go into the firewall to each other. This requires a simple plastic connector from autozone and two clamps. Get some window x antidefrost stuff and a heavy jacket, it's gonna be a COLD ride, but you'll be on the road without any other consequences. Best of luck, this happens to everybody with older cars.
Old 10-15-04, 01:17 AM
Lisayumi
Yikes, it gets really cold in the winter! -10 celcius?? br~~~
I'll probably have to get it done anyhow...gonna use it for another year or two...
yah, and doh! it's an old old car, but i guess i have to stick with it for awhile. I have an older car (chevy sprint 89) which still kicking!! but being used by someone else~
anyhu, thx again. I'll keep you updated-- (yah, once i can get it done--hopefully sooooon! )
Old 10-17-04, 12:21 PM
Lisayumi
Now that the mechanic has my car...it turned out to be a Mazda..
Yesterday, I finally see the leak! all my carpets are wet with green liquid coolant! yikes!
It was much more work for mazda than a ford he said. but unfortunately i had to get it done anyways.
Now..another problem comes up -- well, this has been for awhile.. the car is kindda shaky when I add gas, wut could possibly causes that?? I don't understand.
and I have to go to the ford dealer to buy a "something"cap.. i forgot the name, but it's for the juice ... :P
anyways, I'll write again when i get my car back!
good weekend guys!
Old 10-17-04, 02:02 PM
Radiator cap perhaps?Please don't tell me it's a 710 cap.
Old 10-17-04, 07:34 PM
90dodge
yep, i just bought a 710 cap along with 3 quarts of blinker fluid and drained all my summer air and switched over to winter air. got the high performance winter air to
Old 10-17-04, 09:39 PM
Lisayumi
yup!! radiator cap it is!
wut's 710??
got my car back, heater core is replaced
but then the car still jerking, so i might have to replace the wire--spark wire?they call it?? oh my dad, i have no idea about parts!
hopefully, my car won't cause more problems..or i'm going broke!!
hey guys, give me a hint on 710--wutta hat is that :P
cheers!
Old 10-18-04, 02:03 PM
Lisayumi
By the way, wut could possibly cause the shaking/jerking when stepping on the gas? (around 50km/h).
brake's fine, but tires are not... it gonna cost me $1000+ ?
Old 10-18-04, 02:15 PM
try and be more descriptives. tires won't cost a grand.
btw, my bro had one of these. Ate up transmissions quicker than you could throw at them. Careful at putting too much money into them. where is the vibs coming from?? probably tires. Switch the tires from front to back and see if that makes a diff.
Old 10-18-04, 04:58 PM
Lisayumi
oh no, i mean i've already spend 500+ recently on my car. now i have to replace rediator cap and a wire (dunno wut it call and how much it'll cost) , and may be tires--not sure if i'm gonna replace it now tho. so total cost is probably a grand...
anyhu, wut's the wire that connect the engine called? spark wire? anyone know??
Old 10-20-04, 04:52 AM
carguyinva's Avatar
jeez...
this whole thread is like deciphering code...fortunately i have teenager at home.
spark wire?...probably spark plug wires...get a whole set (shaking only when you step on the gas isn't tires)
710 cap....OIL cap...look at it upside down (hope you aren't blond!)
Old 10-20-04, 02:16 PM
Lisayumi
haha.. no i'm not blond.
but that doesn't mean i'm not dumb
yah, i can buy spark plug wire from anywhere rite??
i dun have to order it from the dealer, do I??
cuz radiator cap, i've got no choice but to order it from the dealer--that's wut the mechanic said.
now that i'm injured, i dun have to work for a bit.. lots of problems r coming my way~~> my car is injured..now my turn.. god bless ~~
anyhu, "poo" happens. hope it doesn't happen to u guys take carez!
