Gasoline Smell
Old 10-17-04, 05:17 AM
dirtgood
Unhappy Gasoline Smell
I have a 1998 Isuzu Rodeo with an intermitant Gasoline Smell. Shows up about every other day. The engine other wise seems to run fine.
Unfortunately, the Rodeo is not having the problem when it goes to the mechanic, so they are not sure where to start. Anyone have some ideas as to what might be causing this?
I like the vehical, and hate to trade it in, but the gas smell is hard to live with.
Help!
Dirtgood
Old 10-17-04, 05:59 AM
the_tow_guy's Avatar
Question:
When you fill up the gas tank, do you stop at the first auto cut-off or do you normally squeeze more gas in?
Old 10-17-04, 01:43 PM
This is easy if it happens every other day leave the vehicle for 2 days so they can see what is happening.Then they can folow the fuel smell themselves or with a emission tester tracking the hydrocarbons.I think it would be easy to find from stains some where due to the fuel leak.Maybe you should take the vehicle to some one that has a smoke machine that will show the leak right away.
Old 10-24-04, 05:29 AM
dirtgood
Problem solved
My mechanic found it. It was a loose clamp on a fuel supply line in back of the engine. Clamp was replaced with a diffent kind of clamp. No more smell. Cost to fix was minor.
Thanks
