starting problems 93grandam
Old 10-17-04, 06:00 AM
big Don
Question starting problems 93grandam
It will turn over but kicks out sometimes up to seven times before it
catches hold and cranks.
It's has a quad four. Found a leak in the bottom hose and have it off.
Trying to get starter off. I have two bolts out but can't get the starter
to come out. Need help! Am at a lost.
Old 10-17-04, 01:08 PM
The starter comes out from the top but the bracket beside the starter needs to be removed depending on the model of quad 4.On installation be careful to make sure that you reconnect the crank sensor connector if you knock it off or it won't start it's below the starter near the front.You will need to tilt the starter to remove it take your time it needs to be almost perfect to come up through.I've done it over 100 times performing a campaigns,about 20 minutes for me to remove and replace the starter and perform the campaign.
